Limits to the TPI intake system
Old Jan 31, 2004 | 09:03 PM
  #31
mrr23's Avatar
ask around on the stealthram board also. i currently run a 12.13 @ 112. here's my personal site www.fl-thirdgen.org/mrr23 documents everything i've done to my car. click the suspension page to see all i've put on. also when you use the desktop dyno, set the induction airflow to say 670 @ 3.0hg (48mm TB) our TB is really a 2 barrel carb per say. not a 4 barrel. only two throttle blades. it'll bring the numbers to something more realistic. the 383 i'm putting together right now says about 466 hp.
Old Feb 1, 2004 | 02:48 PM
  #32
CamaroStylin's Avatar
i made those changes to the dyno program and now it's pumpin out 464 @ 6000 rpms
are you sure it's only 650? that sounds pretty freakin low. Chances are i'll be using the Holley Stealthram and a larger TB (maybe a 52. i doubt i'd go as large as 58 unless it would really help a lot)
you think that counts for anything?
Old Feb 1, 2004 | 03:07 PM
  #33
mrr23's Avatar
over at thirden.org i got a these numbers from someone there.
Stock Throttle Body 48mm 670
Stock with Airfoil 709
AS&M 52mm 750
i suggest not going above 52mm unless you are going to boost (super or turbo) it. even though mike davis runs a 58mm on his 355 and runs 11.83. i'll be using a 52mm holley when i put my 383 in next month.
Old Feb 1, 2004 | 04:44 PM
  #34
ok, and just so i know, what does the @1.5 inHg or @3.0 inHg mean and how does that relate to the performance of the engine?
Old Feb 1, 2004 | 04:54 PM
  #35
mrr23's Avatar
when you go to select what type of induction you'll notice 2 barrel carbs are measured at 3.0 of mercury (Hg). 4 barrels are measured at 1.5Hg. even though it says 4 barrel or FI it's wrong. that's why it shows such higher numbers.
Old Feb 2, 2004 | 02:32 AM
  #36
ZWILD1's Avatar
i've found in desktop dyno you need to make some adjustments to get accurate predictions
cam timing - seat-to-seat timings give more accurate numbers than 0.050"
exhaust - if you have small-tube headers, enter "factory manifolds", if you have large-tube headers, enter "small-tube and mufflers"
intake manifold - if you want to predict HSR or Miniram output, select "Single-plane"
good-luck
edit: a factory 48 mm TB might flow 670 cfm on a flowbench. once attached to a TPI intake flow drops to around 540 cfm. I imagine you'd see the same flow on a HSR manifold.
Old Feb 2, 2004 | 10:58 AM
  #37
why is it that desktop dyno has all these little things that arnt completely accurate? like the exhuast selection and what not?
even with all these things bringing down the numbers it's still listing 462hp and 439 torque. it's got 330 torque at 2000 rpms for gods sake. even those numbers, although they dont match up to what i had hoped for, are still worth working torward given that it would only cost about 2500 dollars for the build.
would you all agree?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jul 4, 2005 05:00 PM
