Lights, Radio, Alarm, ALL WONT WORK!!Help
Old Jul 10, 2003 | 03:39 PM
99TransAmWS6's Avatar
Exclamation Lights, Radio, Alarm, ALL WONT WORK!!Help
My dome interior lights, my headlights, my parking lights, my radio..none of them will turn on..so i figured ah blew the fuse. Its not the fuse! The fuse is fine..i have no idea what it is..the fuse isnt blown what else could it be..i have no idea where to even start looking...help me!
Old Jul 10, 2003 | 10:38 PM
Rice Killer87's Avatar
are u sure the fuse isnt blown? have u tested it w/ a test light,if u ground the test light and touch both little metal "testers" on the back of the fuse while its still in the fuse block,it should light up when u touch both sides...if it doesnt,change the fuse.
if its not that,id say its a ground problem somewhere or its not gettin any power at all.
Old Jul 11, 2003 | 05:29 AM
Don 79 TA's Avatar
My other half is having the same exact issue with the headlights, iterior light, door locks.
just stoped on her. gonna have to look at it in the shop, it's driving me crazy.
Old Jul 11, 2003 | 03:07 PM
the fuse is fine..i dont have a test light...have to see if i can find one..any other ideas??
Old Jul 11, 2003 | 04:48 PM
Slow91z's Avatar
Check any fusable links inder the hood.
Old Jul 11, 2003 | 09:59 PM
kevin 2.8's Avatar
check for loose wires/couplers under the dash?
dealership said my signals didnt work because of 'missing wire to bcm connector'
bastards
Old Jul 12, 2003 | 11:03 AM
Still no luck here guys...i cant drive the damn car if i dont have lights...bad enough without the radio..im lost
Old Jul 12, 2003 | 12:15 PM
Shaun 90 Iroc's Avatar
Make sure all the fuses are the correct amp as well. Try to see how those things not working are related as far as the wires and fuses to them. If you don't have a tester.. stick in a new fuse and see if it works. Look for loose or fried wires.. have fun!
Old Jul 13, 2003 | 11:06 AM
fusiable link down by the starter was shredded. Dunno how..took us a couple hrs to find a 2$ fix.
Old Jul 14, 2003 | 02:08 PM
Slow91z's Avatar
I'm so good I don't know what to do with myself.
squarehead
Jan 15, 2015 07:02 PM
fpete1992
Dec 11, 2014 03:51 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
Paulberg
Jul 26, 2002 11:35 AM
