knocking noise?
Old Apr 12, 2006 | 03:01 PM
92gearhead's Avatar
Question knocking noise?
my motor is knocking is real bad and its not low on oil. i'm not sure what is wrong with it and its the third gen L98 motor.
Old Apr 13, 2006 | 01:05 PM
Z28SORR's Avatar
Re: knocking noise?
If it's that bad it's probably a bad bearing, i.e. rod knock. To be sure you are going to have to find someone with experience to listen to it.
Old Apr 13, 2006 | 02:43 PM
mako350Z28's Avatar
Re: knocking noise?
Sounds like a spun rod bearing to me.
Old Apr 13, 2006 | 05:20 PM
irocalot's Avatar
Re: knocking noise?
you could pull the plug wires one at a time, and run the vehicle to see if the noise goes away - if it does, it's a most likely a rod bearing/wrist pin/broken piston. Next step might be pop the valve cover on the noisy side and check for a broken rocker arm/busted pushrod/broken valve spring - if that's not it, check the torque convertor bolts to make sure there not loose or missing... if that's not it, then you prolly need to pop the motor out and start saving your pennies for a new one or a rebuild...
Good luck, let us know what you find...
Old Apr 13, 2006 | 05:27 PM
LesPaulGoth's Avatar
Re: knocking noise?
Would this really work? I would think he would still get that sound because even though that cylinder isnt getting detonation, its still moving in the same motion as if it were.
Old Apr 14, 2006 | 12:25 PM
Z28SORR's Avatar
Re: knocking noise?
Yes, but there is a noticable change in the sound, gets softer, if it's a bearing.
Old Apr 14, 2006 | 07:46 PM
Dave89IROC's Avatar
Re: knocking noise?
yup, because the loadest part is from the piston being forced down by detonation and the rod hits the crank hard
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
autoxr166
Sep 25, 2015 04:21 PM
SEOJustin
Sep 24, 2015 04:39 PM
