Junkyard Crawl
Old Dec 5, 2006 | 04:44 PM
Speed Demon 505's Avatar
Junkyard Crawl
Hey guys, on saturday I was blessed enough to have the time to go to my local U-Pull junkyard and I found about 10 3rd Gen F-Bodys. However 7 of them were 2.8Ls 2 had nothing in them....but one...was a Formula Firebird. My question is, what did the 1990 Pontiac Formula come with? Was it the 305 or the 350? HO? If anyone could help me it would be appreciated. I may be going down with my cherry picker.
Old Dec 5, 2006 | 06:30 PM
2000GTP's Avatar
They offered both a 5.0 and 5.7 in the 1990 Formula: http://www.thirdgen.org/1990-pontiac-firebird
Old Dec 5, 2006 | 10:18 PM
Stephen 87 IROC's Avatar
It came with 28 spline axles. If it has rear disk brakes, and they're still on the car, they'll be the larger aluminum PBR caliper disk brakes.
Old Dec 6, 2006 | 07:18 AM
teke184's Avatar
probably better suspension as well..if nothing else thicker sway bars.
Old Dec 7, 2006 | 08:54 PM
85_305's Avatar
Very quick cars. Ask Zepher.. he actually held off an ls1 SS for quite a bit w/ his 305 Formula
Old Dec 8, 2006 | 10:45 AM
mmmchickenboy's Avatar
FYI, every vehicle sold in the US in the last 30+ years has an emissions/tune-up sticker under the hood that states the displacement of the factory engine. it wont specify between different versions of the same cid, though. but if you read up on the 3rd gen RPO codes, and find that sticker, you can get all the information you need.
Old Dec 8, 2006 | 10:50 AM
2000GTP's Avatar
A dead giveaway may be the decals on the side of the car as well. The decals that read "Formula" had the 305s and the "Formula 350" had the 350 obviously.
Old Dec 9, 2006 | 03:24 PM
Don350k's Avatar
I thought 350's twisted the frame, or was that just t-top models?
ive alwase frame-kitted my 3rd gens b4 i droped a 350 in for this reason, was i told wrong?
Don
Old Dec 10, 2006 | 11:01 AM
85_305's Avatar
Don
a 350 in itself wont twist the frame Up until the 450fwhp+ range you should be ok.
Old Dec 10, 2006 | 11:21 AM
2000GTP's Avatar
Don
It may be just the t-tops cars, they had a little less structural integrity versus the hardtops. The guy I bought my third gen from had two of his own, two t-tops cars with the 305TPI motors and no motor modifications. The rooftops on both of his cars were pretty severly cracked where my hardtop with 100K on the odometer had none.
Old Dec 10, 2006 | 03:19 PM
Don350k's Avatar
makes sence, my 3rd gen w. t-tops wpold crack winshields left and right when i was hard on her threw a frame kit in and it stoped
Don
Old Dec 11, 2006 | 11:40 AM
85_305's Avatar
Actually it happens to hardtop Camaro's just as much.. well, not AS much.. but it still happens due to being a Unibody. Get some sfc's and fear-not
damnyankee36
Sep 9, 2015 07:06 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Blnk782
Mar 25, 2003 05:24 PM
MustangEater82
Oct 4, 2002 02:51 PM
