inspection plate on T56...
Hey guys! Just wondering if all T56's require the inspection plate.
I bought a T56 kit but haven't installed it yet. I helped a friend install his clutch and tranny on a '97 and he had an inspection plate.
I know their are some variances in T56's... is this one of them or do I need to go hunting for this plate?
Thanks!!
-Ken
Thanks!!
-Ken
What do you mean by inspection plate? Theres a plate on top of the tranny, forward of the shifter, that allows access to the shift gates and skipshift solenoid that's vitally important because it keeps dirt out of the trans. There's also a dustcover that bolts to the front of the bellhousing which is less important, it just keeps rocks and things from hitting the back of your flywheel. You could get away with not having that one but I personally don't recommend it.
The GM unit is very cheap and made to fit perfectly.... $4 for me with my discount plus another couple for the proper bolts for it. Find someone that works at a GM dealer and have them pick it up for you with their discount.
karpetcm
Sep 29, 2015 10:08 AM
. Any decent counterman at the dealer will be able to find it for you in short order though
