Ideal Combustion?
Old Mar 16, 2003 | 06:21 PM
SSXeon5's Avatar
Ideal Combustion?
What is better for 190cc AFR heads: 68cc or 74cc? Thanx
SSXeon
Old Mar 16, 2003 | 06:48 PM
Marc 85Z28's Avatar
What engine are you putting them on? Specifically... What engine size, cam, piston type, head gasket, induction, intended use of engine... There are a hundred different variables which affect ideal combustion chamber size...
Old Mar 16, 2003 | 07:52 PM
SSXeon5's Avatar
Sorry I really didnt know, i know some **** but not too much. The engine I plan to drop in is the GM 350HO, CompCams 264/269 Xtreme Energy, the stock pistons (9.1:1 flat topped), Qjet carb(rebuilding mine), intended use it really for street/strip not full out drag. Thanx
SSXeon
Old Mar 17, 2003 | 10:58 AM
Marc 85Z28's Avatar
Well in that case you don't want either of the two. Assuming you are talking about the 330HP HO 350 - with Vortec heads, you would want at least 64cc chambers. That's what the Vortecs have, and would keep compression at the advertised ratio. Upping the compression to just under 10:1 with a 58cc chamber would be a good idea. It'll keep that cam happy I still don't know why AFR can't offer a 64cc or 58cc head without the extra $200+ milling fee. Their heads are expensive enough!
Old Mar 17, 2003 | 08:42 PM
SSXeon5's Avatar
Hmm yeah ic now. Yeah well they are $1250 a pair shipped tho! Thats not that bad, well if i get domed pistons wont they be ok for 68-74cc chambers and keep high compression? Thanx marc i just really dont know much bout compression but im learnen
SSXeon
Old Mar 19, 2003 | 11:01 AM
Marc 85Z28's Avatar
Yeah, a domed piston will take care of that problem. Just make sure to keep them below a 12cc dome, or your compression ratio will be a bit high. One other thing to note, even with a relatively mild cam like the one you are considering, any time you use domed pistons YOU MUST check for piston to valve interference!
Nayr
Mar 3, 2023 08:34 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Boss002
Jul 9, 2015 03:33 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Chris 96 WS6
Advanced Tech
37
Nov 22, 2002 05:35 PM
