I think I broke the hose for my new oil gauge?
Old Feb 15, 2003 | 12:16 AM
ViperXx's Avatar
Hey all, just curious, I was installing a new mechanical gauge (oil pressure gauge) and the hose was so coil like, as I was installing it it wound back up and it seems that its bent or something in some places which looks like it would block the oil flow to the gauge. My question is, is there any way to fix this or will it be fine or should I get another hose. If I need a new hose, does anyone know where to get just the hose instead of a whole new gauage? Thanks.
Old Feb 15, 2003 | 01:03 AM
jeffsbluez's Avatar
You can run a braided line from the motor to the gauge. Check out summit or go to the autometer web site. They sell the braided lines for thier gauges.
Old Feb 15, 2003 | 03:02 AM
fastcamaro87's Avatar
if the gauge u have uses 1/8 inch compression fittings u can go to your local advance auto parts, pep boys, etc. and get a copper hose kit, u can probably find the same thing at any hardware store/home depot. etc. just get some 1/8 inch outside diameter copper tubing and it should work fine.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
jj71787
Jan 31, 2015 10:20 PM
ro2207
Dec 4, 2014 06:18 PM
