I hear Camaros rattle themselves loose...
Old Mar 22, 2004 | 08:47 PM
BigDaddyWiz's Avatar
Me again with another somewhat stupid question, but I hear a lot of people telling me to keep an eye on nuts and bolts on my car (84 z28 305 HO) for parts rattling themselves loose. I can see what they mean seeing that the suspension isnt designed to handle the **** hole roads we got here in Pittsburgh. I was just hoping some of you could tell me what to look for on my car that is known for coming loose or out of wack after driving on pothole and patched roads that i gotta deal with. Once again, I'm new to sports cars after having been driving a jeep around that can handle bumps in the road no problem. Thanks again.
Old Mar 22, 2004 | 09:04 PM
89-Camin-Camaro's Avatar
The only thing like that I've ever heard of is the steering column mine did it and my friends also did
Old Mar 23, 2004 | 02:32 AM
kandied91z's Avatar
depends how bad the condition of your car is. considering it's a unibody style if your suspension is in proper order and your not running some rediculous thin sidewall tire you should be fine....think you have bad roads visit detroit sometime.
Old Mar 23, 2004 | 08:13 AM
PyRo9862's Avatar
I found a loose bolt on my starter, and I discovered that horrible creaking noise was a loose bolt on my swaybar. Although the swaybar is probably my fault as I recently put in a wonderbar before that incedent.
You will find more of a problem getting rusted seized bolts out when you need to change somthing then them comming out on there own.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ChrisFrez
Dec 7, 2014 06:01 PM
jayblev95
Dec 1, 2014 06:55 AM
squarehead
Nov 21, 2014 08:02 PM
Klypto
Jul 19, 2002 07:25 AM
