How to get dist. rotor off??
Old Jul 2, 2003 | 01:49 AM
96cam4ro's Avatar
While I was swapping out my whole ignition system (plugs, wires, cap) I tried to get the dist. rotor off but I couldn't. I mean I pulled like crazy and the damn thing just stayed put. I can't see any bolts holding it down. It's for the TBI. Does the rotor stick on the distributor or did mine just get stuck? Or is there a special twisting movement I have to do to get it off? Thanks.
Old Jul 2, 2003 | 03:30 AM
Sitting Bull's Avatar
It should just pull straight up and off.
Squirt some WD40 on it.
Old Jul 2, 2003 | 07:14 AM
Craz-28's Avatar
Yeah, it's probably stuck on there really good. All you need to do is pull straight up real hard and it should pop right off. Never tried using WD-40 but it may be worth shot.
Old Jul 2, 2003 | 02:58 PM
slayer6x6's Avatar
Mine was really on there, I had to play with it for a few minutes before i got it off. I never tried wd-40, but that would be a last resort imo.
Old Jul 3, 2003 | 06:08 AM
Fast_89rs's Avatar
wd-40 wont hurt a thing....it is great for removing moisture from a cap.
Old Jul 5, 2003 | 10:14 PM
kjlvilla's Avatar
I had to use a big pair of channel locks to grip it and wiggle it back and forth while I pulled up. The shaft gets rusted and locks the rotor on. It's not the best design but works. As a last resort, you could cut it off with a die grinder. The only bad thing is the dust that will get everywhere. Good luck.
Old Jul 6, 2003 | 01:07 AM
kevin 2.8's Avatar
Angry
gentley.......... smash it!
93 RedBird
Nov 15, 2015 08:24 AM
HibachiZ28
Nov 6, 2015 12:53 AM
jayblev95
Sep 26, 2015 09:44 PM
Henson071
Sep 18, 2015 04:01 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
