Hood Clearance
Old Mar 23, 2003 | 06:22 AM
KarmaCult's Avatar
Hood Clearance
I am buying an Edelbrock performer intake for my matching carb (edelbrock perf) and my question is simple, as I'm sure atleast one of you have tried this combo.
How much of a hood clearance issue am I gonna have? not like "will it be there" cause it will be I'm just wondering like how many inches of clearance I would need, I assume nothing over 2 inches is over kill, but still I must ask, will it fit under stock at all, and if not, how much of a cowl or scoop (or even hole in the top of hood) would I need
Cause I'm finishing it all up on the 1st (when the intake is ordered) so I need to just put all the "don't fit" things onto a list so I can try to find away to fix them.
-Karma
Old Mar 23, 2003 | 10:52 AM
Montty Garrett's Avatar
It will clear, Had this combo before I when to a torker 2. No clearance problem at all. I have, I believe a 2 inch or so air ceaner. Just make sure that your air cleaner rod is not to long or you will put a dent in you hood. Good luck
Old Mar 23, 2003 | 11:24 AM
AndrewC's Avatar
clearance
Yes, when I ran that combo and a proflow tri-angular air cleaner the hood would crunch the top of the air cleaner. It does fit but really tight.
I like it all under the hood so no-one knows what you are runnin.
Old Mar 23, 2003 | 12:22 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Ive got a Torker II and Edelbrock carb on mine now with one of those triangle looking edelbrock air cleaners and Ive still got like an inch or two.
Old Mar 23, 2003 | 09:10 PM
TheGreatJ's Avatar
Performer RPM, Edelbrock 750, 14x3" K&N with a 1" drop base air cleaner under the stock hood and no clearance problems
Old Mar 24, 2003 | 12:19 AM
KarmaCult's Avatar
Smooth
Thank you guys for the help
I would like to remain stock appearance as much as possible, as stock is best for street racing, the cops don't know your kick *** and either do all those damned hondas
another fast question, what kind of gain should I expect with this setup? I dunno what I'm expecting from any of this, I'm mostly just doing all this just to replace all the old tired stuff on the engine.
Thanks again you all
-Karma
Old Jul 6, 2005 | 12:59 PM
86 redbird's Avatar
Re: Hood Clearance
I assume all of you have camaro's. What about firebirds, do they have the clearance issues with the performer rpm? I have a torker 2 and I want to go with a dual plane.
Old Jul 6, 2005 | 01:31 PM
rollingstock's Avatar
Re: Hood Clearance
i think the year also helps. it seems to me that the older(around 86) camaros have more room.. i know on my 89 just with a pro-flow air cleaner hits the hood... the 86 we have here has an bigger aftermarket carb with spacer and cleaner isnt hitting.. both cars have 305s
i duno if the fiberglass hood on the 86 has anything to do with it..
Old Jul 7, 2005 | 10:22 AM
Tru2Chevy's Avatar
Re: Hood Clearance
Yup - pop both hoods and look underneath. The 'glass hood doesn't have all the bracing that a stock steel hood does.
FWIW - I have a performer with a non-CC q-jet and a 14x3 1.5" offset air cleaner hit when I closed the hood. Ordering a 14x2.5 offset and taking out the center hood bracing to fix the problem
- Justin
Stephen68
Oct 16, 2015 03:50 PM
CARiD
Sep 30, 2015 05:44 AM
gearhead3
Parts Wanted
Sep 16, 2015 08:18 AM
Daluchman1974
Sep 11, 2015 06:12 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
