holley 650 DP
holley 650 DP
hi I got a Holley 650 DF DP MS and I want to bolt it to my 305 (it`s not stock lol) but I have a problem the 1 time I bolted it to the engine it had a high pitched sqealing vacuum leak to it and reved at 2500 RPM at idle so I took it off.... now today I wanted to try again and I bolted it to the engine with 2 gaskets this time and the high pitched noise went away but now it idles at 4500 RPM YES 4500
, is this a sign that the power valve is blown??, I don`t know much about Holley`s and lost my Holley book so I`m not sure whats wrong with my Holley? I have a 600 SP SF VS Holley on it that I want to replace with the 650, and yes I`m goin to a 350 VERY soon like in the next month
and REALLY want to run the 650 on it
Re: holley 650 DP
I looked closer at the 650 today and found out that butterflies arn`t closeing all the way at idle So I got the take the primary shaft out and lube it all up and straghten out a couple of bent parts I found and try again
RUENUF
Mar 13, 2016 03:37 PM
