heres what ive planned so far for my rear have i missed anything
heres what i decided, the zexel heavy duty rear from slp with 373 richmond gears also the 28 spline axles from moser with the solid aam cover now is there a bearing kit i need that has all my bearings and seals so i dont leak ou to fmy rear. a solid bearing sleeve and stud gridle to
You need some good lube for your rear end before you put the shaft........
Seriously, you do and maybe even friction modifier or whatever it is they call it. On the new GM trucks, the redesigned the rear end so it uses a synthetic fluid and no modifier.
Also you will need drive and driven gears for the tranny otherwise your speedo will not read right.
Jan 13, 2015 09:52 PM
