HELP!!! Timing
Old Jun 26, 2004 | 12:20 AM
maropowered305's Avatar
HELP!!! Timing
What is the timing on a 1984 Camaro Z28 LG4
Old Jun 26, 2004 | 01:35 AM
jconrad's Avatar
6 degrees advance is what I used to run my 83 at. Just remember to unplug the four wire connector by the ditributor before you set the timing. That is the computer advance control. Without unhooking that, I've been told that whatever you set it to will be about 5 degrees retard.
Old Jun 26, 2004 | 06:24 PM
Damon's Avatar
Stock spec is 0* BTDC. As conrad said, you can bump it up about 6* from that spec (6* BTDC) pretty safely for better performance with no real ill effects.
If you were wondering where your timing tab is located (many people have trouble finding it) just look straight down behind your water pump.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
