HElP SES light
HElP SES light
I was driving home from school today and My SES light came on. The car didn't run differently or anything, and I brought it home and ran the code. It came up as 53............what is my problem?
It is in an 86 lg4 ta.
Any help would be appreciated.
hey bro, this is code 53
EGR Control
Leaking; restricted or improperly routed vacuum line
EGR valve stuck or leaking
poor electrical connection
open or short in circuit
defective egr solenoid
defective ecm
But since this has never happened to you before, my guess is this other code 53 might be it
System Over Voltage
Charging system problem
Hope that helps bro!!
Will
EGR Control
defective ecm
System Over Voltage
Will
well i looked that up last night and i couln'd make any sence of it. How do I pin it down to one of those things?
It did it when I was driving for about 10 minutes at 60 mph and then when i shut the car off and turned it back on it didn't come back..........
Could just be a freak occurance, but when you turn the car off, it won't come ack on right away, unless you experience the same problem. But thats what my manuals gave me about code 53.
Will
Will
It is not all of the time, but occasionally the light will come on only after about 60 mph. Sometimes it shut itself off, and sometimes it just stays on. Everything checks out, so I figured no big deal and now I just ignore it.
If you figure out what it is let me know.
I have had and maybe still have this problem. Check this out
http://www.thirdgen.org/newdesign/te...diagnose.shtml
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Z28Wilson
Aug 1, 2002 04:27 PM
