Help!! Glowing Header Tube
#18
Yea, I"m going to do that route once I get her scoped on Monday, that is if it is not snowing here! Can't beleive it, it rarely snows in the city here in Seattle, but has for the past few days! And crappy timming! I may take it there anyway! But yes, I plan on taking down the top and tryign to see if that is the problem.
I'll let you know what I find!
thanks agan!!!
thanks agan!!!
#21
Night,
BS! My corvette headers glowed orange after my cam upgrade. I had to increas the fuel psi to meed the new fuel demans. Both lean and rich conditions can create the glowing header problem.
I think I found the problem. I never took off the passengers side valve cover. Well, out of curiosity, i took it off. The no.6 intake and exhaust rocker arms were broken. I read a lot of posts that AFR had problems with their screw in valve studs. One of mine broke off while i was backing off the rocker nut with mimumal pressure! Needles to say, I'm replacing all of my screw in studs! And calling AFR today! You think with such quality performace heads, that they woudl give you the best of everythign else including screw in studs and the heavy duty springs!
I'm opening her up today adn will keep you posted! TY all for the help!
oz
oz
#22
well thats really funny because my #4 cylinder was running lean for a long time thanks to an injector snafu and the paint never burnt off the primary. I cant see how a lean cylinder will create extremely hot temperatures when less fuel is being burnt.
#23
#24
Originally posted by aklim
The leaner it gets the hotter it gets. Possibly detonation. Fuel also cools down the cylinder walls.
#25
I cant explain why exactly, but I know that running lean causes hot cylinder temps(think of the fear on N2O users, lean burn and melting a hole in a piston), and running rich causes cooler cylinder temps, the reason you could get a glowing header tube from running rich is the extra fuel is burning in the exhaust
#26
think of an oxy/acc. tourch. More o2, makes the gas hot. So if it's running lean, it is probably giving enough fuel to burn to it's max specific heat (min % of fuel with max % o2). Rich can also cause the tubes to get red hot.
#27
i bet they are 3/8 studs. i ONLY run 7/16 on my setups. if you can locate a set of rockers cheap, the 7/16 will screw right in where the 3/8 came out.
both studs use 3/8 NF thread on the bottom side into the head.
good luck with it!
good luck with it!
