HELP! determining ring gear size
Old Jan 26, 2003 | 10:31 AM
thisoldcamaro1's Avatar
I am trying to make my 82 z28 a little more streetable by downsizing the gear ratio to something a little more gas-pump friendly. The rear end is a gm limited slip 10 bolt out of an 83 firebird. Is there a way to measure the ring gear size without removing it (so I can order a new gear set) ?
I think its a 7.5 with a 3.42 ratio. With a 245 50 r16 tire at 75mph I'm at 2600 rpm.
The trans is a stock 4l60E. I'm sure its in OD and I'm sure the torque converter is locking up.
Any help or opinions would be greatly appreciated.
Robert
Old Jan 26, 2003 | 12:18 PM
angel71rs's Avatar
I ran your numbers and you should be turning 2300 rpm at 75 in od, assuming the tire is 26" tall.
3.90 = 2600 in od. But your 4th must be kicking in otherwise your rpm would be 3700.
Consider buying a complete diff with the gear you want, or trade with someone who wants a deeper gear. You will not just have to buy the gears, but pay for the install. And not just anybody can do a r&p job, and do it right. Around here, posi 3rd gen drum diffs can be had for 100-200 hundred bucks.
Old Jan 26, 2003 | 01:41 PM
Stephen 87 IROC's Avatar
The early third gens have a 7.5" ring gear. Around the mid 80's it was increased to 7 5/8" but is still considered a 7.5". Parts are interchangable.
1982 didn't offer an A4. You don't have a 4L60E unless someone installed it from a later car. The A3 will be a TH200c
Old Jan 26, 2003 | 09:08 PM
Thanks guys, I appreciate the info.
P. S
I do have a 4L60E, I did an Lt1/4L60E conversion from a 94 z28 about a year ago
HectorM52
Jul 30, 2017 11:46 AM
ChrisFrez
Feb 15, 2015 08:12 AM
ChrisFrez
Feb 1, 2015 08:26 AM
ChrisFrez
Dec 21, 2014 09:47 PM
