Help! Computer Controlled Quadrajet Questions
Old Aug 10, 2004 | 05:38 PM
  #16
ws6transam's Avatar
Re: Help! Computer Controlled Quadrajet Questions
Originally Posted by Pneumatic_Tire
cant find this wiring harness nowhere for the torque converter, cans someone help me out again? i dont want to mess this up.
If you are going to run without the computer, you will need to supply +12V to the lockup clutch whenever you want to cruise. Want to use a switch? A simple toggle switch ought to do the job, as long as you remember to UNLOCK the converter when it's time to slow down.
The connector on your transmission is just a three-wire connector, IIRC. You'll find that it goes into the wiring harness at the firewall, on the passenger side of the harness, behind the valve cover. That will be where you'll want to cut and splice in your circuit.
I'll edit this thread with more information later, as I have to quit typing and sit down to dinner.
Old Aug 11, 2004 | 12:02 PM
  #17
Marc 85Z28's Avatar
From what I am aware of, there are a few different ways the 700 was wired, but this should be the one you need:
700-R4 wiring diagram
In addition to ws6tansam's switch method: It will work fine. However, as a safety precaution, wire the brake light switch to cut power to the TCC. Just in case you have to make an emergency stop and don't have time to flip the switch
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
ScottZ
Mar 3, 2004 01:34 PM
SLIMJIM
Jan 7, 2003 11:06 AM
JasonD
Jul 15, 2002 02:17 PM
