help
Old May 11, 2004 | 02:32 PM
chevyman502bb's Avatar
help
ok so no L98 for my car cause skeeter is affraid of a lil wireing....so what he wants to do is find a 350 and pop her in using the TBI.....what will i need to do to the FI?
Old May 11, 2004 | 06:16 PM
TheGreatJ's Avatar
You'll need reprogramming. The 305 computer is NOT going to like the extra displaement. However, you could find a 350TBI truck in a junkyard and snag the computer, the knock sensor, and the larger throttlebody off it and probably be just fine. If you make any major changes while the engine is out (i.e. cam swap or head work) then you'll still need programming.
You NEED the 350 knock sensor. If you use the 305 sensor in the 350 there's a good chance it will pick up false readings and retard the living **** out of your timing.
Old May 11, 2004 | 06:27 PM
yeah, im gunan try to convinse skeeter to do a carb on it, he and my dad dont like to listen to "the stupid 16 y/o"
ill get back to u guys
