Heated O2 sensor
Old Feb 4, 2005 | 11:19 AM
pigsticker's Avatar
Heated O2 sensor
What is the advantage of a heated o2 sensor over a non-heated one?
Old Feb 4, 2005 | 11:41 AM
five7kid's Avatar
For 3rd gens, typically used with long tube headers. It just insures the O2 sensor is up to temp and operating by the time the CTS tells the ECM to go to closed loop.
Old Feb 6, 2005 | 01:30 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Re: Heated O2 sensor
To elaborate, the O2 sensor needs to be hotter than 650 degrees F to work properly. When you put on headers, you are moving the O2 sensor further away from the hot engine. With a heated O2 sensor, you are putting current thru it, which heats up the element and allows it to work better.
Jun 19, 2015 01:34 PM
Jan 23, 2015 01:13 PM
Injuneer
Dec 15, 2014 09:36 AM
Jul 4, 2005 05:00 PM
JurisAg02
Jul 27, 2002 11:49 AM
