Headlights acting up.... Please help
Old Nov 9, 2004 | 07:46 AM
buzz12586's Avatar
I was driving home last night from work when I noticed that it seemed dark in front of me. My normal headlights weren't on. I tried turning them on and off but nothing happened so then I hit my high beams to see if that worked and it did. I got home and checked it out and unless I have the high beam switch on my headlights won't come on. Any idea what it could be???
Old Nov 9, 2004 | 08:52 AM
Kwiksilverz28's Avatar
Re: Headlights acting up.... Please help
2 blown headlights? Stranger things have happened. Check the plugs for power....
Old Nov 9, 2004 | 03:19 PM
buzz12586's Avatar
The funny thing is they work when I flip the high beams on so they are getting power that way. I will check when the high beam switch is off.
Old Nov 9, 2004 | 07:26 PM
Yea. There are 2 filaments in the bulb itself. I was not just being a smarta$$. Very possible..... Let me know! I will feel better about Murphy's Laws not only against me! LOL!
Old Nov 9, 2004 | 07:57 PM
buzz12586's Avatar
So even the low beams have 2 filaments?? I have 2 sets of headlights, one for high and one for low.
Old Nov 9, 2004 | 07:59 PM
Hmm...No. Your camaro has one filament in each bulb. Sorry, I was thinking my firebird. But still, it is possible that both blew at once....
Old Nov 9, 2004 | 08:16 PM
NJSPEEDER24
Guest
Posts: n/a
Two bulbs out..sounds like a loose connection. I'm not sure if the car's lights are hooked up in series or parallel though. High beams and low beams run seperate wires and two low beam bulbs out = loose connection/high resistance somewhere between the switch and the bulbs probably.
Old Nov 9, 2004 | 09:48 PM
buzz12586's Avatar
What I did for now is unplug the high beams and just leave the high beam switch on all the time. My low beams stay on and work fine but if I turn off the high beam switch they turn off. What gives???
Old Nov 9, 2004 | 10:02 PM
NJSPEEDER24
Guest
Posts: n/a
Sounds like you have some wires connected in the wrong places maybe, also you might not be getting enough voltage to share..that was a quick theory I'll think about it more and post later I got a lot of hw
Old Nov 10, 2004 | 10:06 AM
Damon's Avatar
YES, the low-beam (outer) headlights have 2 filaments in them. One for low beams and one for high beams. The high-beam (inner) headlights only have one.
Low beams it turns on only the low beam filaments in the outer headlights.
High beams it turns on the high beam filaments in the outer headlights AND the (only) filaments in the inner high beam headlights.
You could very well have 2 burned out headlights.
Old Nov 10, 2004 | 02:27 PM
buzz12586's Avatar
Damn, that sucks. Thats weird that they both went at the same time. These didn't even last that long, they are silverstars. I guess its time for some new headlights.
Old Nov 10, 2004 | 02:28 PM
IROC-T's Avatar
This info is correct so basicly you are driving with high beams on all the time. you could have a bad switch at either the dash or the dimmer switch also,check and clean the plugs at the lamps as well.
Old Nov 10, 2004 | 02:30 PM
buzz12586's Avatar
Well the parking lights and everything come on, so I assume the dimmer switch is fine. I'll check it out though.
Old Nov 10, 2004 | 02:34 PM
IROC-T's Avatar
Not the **** that dimms the dash lights the one you use to change from hi to lo beams in the colum.
Old Nov 10, 2004 | 02:43 PM
buzz12586's Avatar
It turns the high beam icon on in the dash and turns it off. It also turns on the high beams. When it is off the low beams just don't come on.
