Headlight switch replacement
Old Feb 20, 2003 | 10:12 PM
Tremo's Avatar
Question Headlight switch replacement
ARGH!!! The dash light dimmer in my headlight switch burned out and now my dash lights are OUT. When I turn the **** all the way up to turn on the dome light, the dash lights come back on, so it's not a blown fuse or broken wire. So... who makes the BEST replacement? Please note that I replaced the 194 bulbs in the cluster with brighter 168s, so that may be why the thing failed. I guess I'm looking for a switch with a dimmer that can handle the extra load. Suggestions? Thanks!
Old Feb 21, 2003 | 08:21 AM
Jim85IROC's Avatar
Sometimes it's just an issue of the switch being dirty. Sometimes my lights don't work until I twist or jiggle the **** a little. As for replacements, if you find any aftermarket one at all, I highly doubt it'll be any different than stock.
Old Feb 21, 2003 | 01:18 PM
CODY BEHNKE's Avatar
Being that it is a multi function assembly they isn't an aftermarket unit. Only OE replacements.
ChrisFrez
Feb 15, 2015 08:12 AM
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
CaRParts102
Dec 6, 2014 08:45 AM
