Haynes auto manuels suck.
Old May 6, 2004 | 08:53 PM
Pneumatic_Tire's Avatar
Why can't they give me the distributor caps cylinder numbers? How am I suppose to know which is number 1 on the cap? I know the whole take out number 1 spark plug and crank the engine just until you feel the compression come outta it, and the rotor should be directly under the first cylinder's terminal on the cap. I need to know this exactly, cause I'm unsure of the distributors rotation. Is it clockwise, or counter clockwise. I hooked everything up clockwise, and the car wouldn't start. Only backfire when trying to start. So I gave up for the day before I took an ax to the engine. LOL, help me guys! 85 z28 305 computer controlled quadra jet 4bbl.
Old May 6, 2004 | 09:47 PM
TheGreatJ's Avatar
You're leaving out one all-important step. After you feel compression on #1 you have to roll the engine around manually until the timing mark lines up at 0* (the top-dead-center position.) THEN the rotor should be pionting at the number 1 cap terminal.
Also the rotor turns clockwise.
Old May 6, 2004 | 09:48 PM
TheGreatJ's Avatar
Also you're right.....Haynes does suck.
Old May 6, 2004 | 09:49 PM
Oh crap thats right. Thanks GreatJ. Nevermind about the distributor cap number order, I found it on Autozones website of all places. Get in the zone.
Parts Wanted
May 1, 2016 10:25 AM
drt
Sep 27, 2015 04:39 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
scottcba1
Sep 8, 2015 09:52 AM
tdigger9899
Sep 7, 2015 10:56 AM
