Having heads ported What size FelPro is recommended?
Old Mar 31, 2003 | 05:04 PM
RedIrocZ-28's Avatar
Just like the topic says, Whats a good size FelPro to use as a base for porting?
I have been looking for a little while here and can't seem to find the answer to my question.
FelPro 1205? Its a bit bigger than a stock gasket right?
Would somthing else work better? I am having the heads ported more than just a little bit. Its gonna be a full port job. Going into the ports and what not.
Recommend!
Old Mar 31, 2003 | 06:30 PM
Sitting Bull's Avatar
I think your best bet are stock gaskets. Usually, your port openings will have quite a few irregularities that must be ground away to conform to the stock gasket outlines.
I have found, however, that an intake manifold like an Edelbrock Performer will fit the gasket perfectly with no need for any grinding at all.
Old Mar 31, 2003 | 07:36 PM
Aron213's Avatar
If your having them opened up a 1205 will work, but do keep in mind that without a flowbench, backyard porting to "opening up" can be taking a step backwards if someone is using a flowbench then go 1205.
If your just matching, take your largest port and match to it, not match to a gasket, also most your gains in the runners will be found on the roof not the floor.
HectorM52
Jul 30, 2017 11:46 AM
cmyname1
Feb 19, 2015 08:38 PM
Roadie
Feb 16, 2015 10:34 AM
Killer94z
Jan 13, 2015 12:06 PM
