HATCH pulldown motor
Old Apr 30, 2003 | 01:41 PM
Brett 91 RS LT1's Avatar
Hmm, this is new. I haven't had to use the hatch since last Fall, so the motor has been unused. I opened it today (the release switch inside the car works fine) and the hatch jumped open - no problem. After a while of cleaning things I went to put it back down.
Now the hatch will lock into the motor, but the motor does not pull down. No noise, no movement. The release solenoid works fine, but that is a separate part.
Does this mean the pulldown motor is dead, or is there something I can fiddle with that might get it to work? I did notice that one of the 4 wires in the connector to the motor was corroded. I did my best to clean it off, but still no dice.
How can I try to get it to work?
And if it is dead, how much do these motors cost?
Thanks guys!
Old Apr 30, 2003 | 03:30 PM
thezisking's Avatar
Right behind the back of the latch, there is the lever for the motor. Push is dpwn and see if it moves (don't worry, it won't catch your finger). If it don't, take the trim off and get a motor for a junk yard. Shouldn't cost you more the 20 or so.
Old May 1, 2003 | 07:47 AM
irocz8957's Avatar
yeah its probably going bad there not to expensive though!
Old May 2, 2003 | 10:54 AM
fbird95's Avatar
Not expensive. I always see them for a killing even remanufactured. They are one of the most sought after salvage and junk yard f-body parts. If you know where to get them cheap, spread the word around.
Old May 3, 2003 | 06:41 PM
ebmiller88's Avatar
Contact Lon at Top Down Solutions, he'll hook you up.
http://www.top-downsolutions.com/default.php
Ed
Old May 5, 2003 | 04:19 PM
clasbya's Avatar
I was about to say, there is a salvage yard here that specializes in firebird and camaro of all years. I woud imagine you can get one from them between 12-22 dollars.
Old May 7, 2003 | 12:23 PM
fbird95's Avatar
Just sending this to the top, because someone else was having rear hatch pull down problems and i suggested they go to the site listed below.
Old May 8, 2003 | 10:56 AM
thezisking's Avatar
http://www.thirdgen.org/newdesign/te...chpulldown.pdf
shroyvin56
Apr 3, 2015 08:15 AM
dale3in98
Feb 14, 2015 12:18 PM
Jan 13, 2015 09:52 PM
Alien
West South Central
Jan 11, 2015 12:51 PM
