Harland Sharp 1.65rr on PONTIAC heads - clearance?
Old Jan 28, 2005 | 09:05 PM
BluBiU's Avatar
I ordered a set of Harland Sharp 1.65rr and i've read on the net that i will need to clearance the pushrod holes a 'tad' to make them work..
My questions is how much is a tad? I know i need to grind material on the side closest to the stud but how far down should I go and how much closer to the stud should I go? Also, should I retain the guide plates with the Harland Sharps?
Regards
*** edit ***
BTW: the engine is a 1978 Pontiac 400cid.. the heads are Casting #16's out of a 1969 GTO RAIII (D port heads)
Thanks..
carl.froehlich
Mar 13, 2015 12:38 AM
Roadie
Feb 16, 2015 10:34 AM
Chris Anderson
Jan 27, 2015 08:30 AM
Jazsun
Dec 29, 2014 12:14 PM
