Gutting air box. How do I do it?
Old Jan 26, 2003 | 09:47 AM
stk350's Avatar
I'm looking to pick up a few extra hp. I'm assuming you can gut the factory TPI air box for a little better air flow. Has anyone attempted it? I'm just afraid I'll pull it apart and not be able to seal it back together right.
Old Jan 26, 2003 | 10:44 AM
CODY BEHNKE's Avatar
On my 86 and 90 I just did what most people have done. Take the filters out, Remove the air box, then take the small baffles out then use a saw or dremmel to cut the bottom portion og the boxes off.
Old Jan 26, 2003 | 10:52 AM
Fast_B4C's Avatar
Yah man thats what I did. It does the job, your not going to break anything. They might have something on thirdgen.org. You might want to check them out. GoodLuck
Old Jan 26, 2003 | 01:38 PM
aklim's Avatar
I went with SLP's Cold Air Induction kit.
Old Jan 26, 2003 | 02:25 PM
When you have an intake such as the one on TPI IROC's a CAI has no real advantages.
Old Jan 26, 2003 | 05:26 PM
stevem's Avatar
i cut out the bottom of the air boxes and got rid of all the plastic crap between the condensor and the front clip. I also removed the rectangle shaped pieces where the for lights are. then i went to home depot (ducting section)and got an adapter that went from the square (air filter side)to a three inch circle. i screwed the square side to where the air filters go.then i got a 90 degree piece that was 3 inch circle to about 8 to 10 inches across and 4 inches tall and mounted that behind the for lamps.i did every thing twice becauce there are 2 sides.the intake does not move at all very rigid.if you use ducting hose it will vibrate and cause turbulance.i had my fog lights out for about 2 months but i put them back in because it looks better.the cool part is you cant even tell its there.hope this helps.
P.S.--- YOU WILL HAVE TO CHANGE/CLEAN YOUR AIR FILTERS MORE OFTEN(get some kn filters if you do not already have them.
Old Jan 26, 2003 | 11:44 PM
stk350's Avatar
Awsome guy's. Thanks. Now, what about the Y-shaped factory plastic piece? You know, the piece that goes from after the filters to the MAF. Is there any way I can gut that. I heard there were sound baffles in there.
Old Jan 27, 2003 | 12:57 AM
stevem's Avatar
i dont think there are baffles in there
Old Jan 27, 2003 | 12:15 PM
teke184's Avatar
when i had my 87 iroc i removed some material on the Y piece. i shaved the square part just above the perches for the filters, don't think it did much but i figured it didnt' hurt.
on the other end of the Y i found a small lip on the inside of the round tube, just before the end, that went across the bottom of the tube. i removed that, resulting in a small hole in the bottom of the tube which i just filled in with fiberglass
Old Jan 27, 2003 | 12:20 PM
82355's Avatar
I did it to my cousins Iroc for him the other day with a sawzall took all of 5 minutes for the whole operation. Not exactly tough. Use a 7mm socket to remove the four baffles and then cut the bottom of the air filter housings off. It is really self explanatory when you pull it out.
Martin
Old Jan 27, 2003 | 12:52 PM
aklim's Avatar
I was getting other parts too. I was too smart to believe that the CAI is all I will do. I had a Firebird which had the tube going to a can with a 3 in hole in it. The new air tube looked pretty much like the old stock one except it had a piece of aluminum in it to break up turbulance in the air intake from the hole in the fender that was already there.
Latronaxe
Apr 29, 2015 08:25 AM
95chwagon
Jan 13, 2015 09:19 PM
Notford95
Aug 20, 2002 01:46 AM
