got my Iroc running well kinda
If any of you can remember any of my previous post you will recall that I bought a 89 Iroc conv that needed some attention under the hood. I figured out that I neede a new pump after installing the pump it ran fine no problems until the next morning it didn't want to start at all, but it finally did after it starts it runs and will even start back up easy. I checked the fuel psi and it was fine,but when you shut the engine down the psi dropps seconds later.
My camaro sat up for a little while. After I got it back running it was hard to start and didn't run perfect. Found out that I had a couple of injectors that was sticking. after a few days of driving it, it was fine.
