good rear end for 300+ hp?
Originally posted by ws6transam
Yeah, I probably will end up with a Moser 12 bolt eventually as well. The new engine (which is close to being done) is estimated to be 460 to 480 horsepower at the crank, and just as many foot-pounds of torque. I don't know what it'll do to my Torsen & Moser equipped 10 bolt. I probably shouldn't try runnng any slicks at the strip though, until the new axle is installed in a few years. I'm thinking the car will E/T in the high 11's at 120 MPH on drag radials.
Once I can save for a 12-bolt though, I might try those Nitrous spraybars that are already mounted in the intake! The shortblock is built strong enough for 700 HP and the pistons / combustion chambers/valves are all ceramic thermal barrier coated.
I doubt my little 7.5 inch Richmond gearset was designed for that kind of abuse.
You would be suprised of how much abuse that litle ole 7.5 10 bolt can take ! I have a friend here that has a 85 monte with 383 stroker in and is pushing 710 hp and 650 rwtq on a factory 7.5 !!! I am amazed that it has not broken yet......This car has dual stage nitrous (250 shot) and a t-56 in it also
shoot... i know a guy running a 355 Procharged LT1 putting down 475+ hp and he hasn't shattered his yet... probably will soon... but he has probably 30 passes on his stock 10 bolt and its been fine...
oldschool
Feb 9, 2016 09:21 PM
