Is This a Good Price for a 383?
Old Mar 6, 2004 | 03:41 PM
GTO2Z28's Avatar
$2200
Fully assembled
350 4 main block
Performer Intake
480/230 cam
GM Crank and 2.02 1.60 heads
ARP bolts
a bunch of other stuff that I cannot remember.
Doesn't include carb, distributer, and accessories from old engine.
This is the jest of what my friend told me the local engine guy quoted him for this engine for his 86 TA. The guy said at least 410 horses out of it at the crank minimum. What do you all think?
Old Mar 6, 2004 | 08:18 PM
Rice Killer87's Avatar
sounds pretty good to me. its not forged is it? that would be a real good deal if it was
Old Mar 6, 2004 | 08:31 PM
GTO2Z28's Avatar
I don't believei it is. He mentioned something about not running nitrous on it. I will check and see. Does anyone think 410-450 is too much hp for this setup?
Old Mar 6, 2004 | 09:14 PM
97WS6SCharged's Avatar
What kind of heads is he using and what are the specs on the cam?
Old Mar 7, 2004 | 05:57 AM
GTO2Z28's Avatar
It lists it up top, but 230/480 on the cam, and normal GM 2.02 1.60 heads.
Old Mar 7, 2004 | 06:05 AM
I meant casting numbers for the heads, you can stick 2.02/1.60 valves into just about any SBC head, but that doesn't mean it will perform well. And as far as the cam, going by those numbers, I'm going to assume it's a single pattern cam with 230 degrees intake/exhaust and .480" lift.
Old Mar 7, 2004 | 06:28 AM
GTO2Z28's Avatar
Sorry, I misunderstood. I don't have the casting numbers. I have seen the sheet the guy gave my friend, and it just gave those numbers. They are GM heads, but that is all I know. For the cam, I believe that might be on a 110 LSA also, and you are right for those numbers.
Old Mar 7, 2004 | 07:55 PM
for only a .488 lift cam,i dont see 410 HP w/ some GM heads. it might have Vortec heads (great street head) but that small cam wont push it to 410 i dont think. ask him for a dyno sheet.
Old Mar 7, 2004 | 08:00 PM
GTO2Z28's Avatar
Vortec heads sound right.
Old Mar 7, 2004 | 11:44 PM
kandied91z's Avatar
must not be a forged crank or even hyper pistons. if it is a 4340 crank that would be a great price for the shortblock alone and if he used at least hyper pistons too that would be a steal if it worked right.
gm's 4340 383 shortblock fully assembled is 3400 which uses the forged crank and hyper pistons just to give you an idea.
Old Mar 8, 2004 | 07:47 AM
aklim's Avatar
It is a good price for a 383. Whether that is a good 383 or not, I doubt it personally, remains to be seen. Pretty low lift cam, IMO, for that kinda power it is supposed to make.
Old Mar 8, 2004 | 11:45 AM
Slush92RS's Avatar
AS for that cam, i had a 490 lift cam with similar duration in my 388 stroker and i only dynoed 319 RWHP! That is using AFR heads and a 750 Demon carb on top of a Performer RPM air-gap manifold. CR around 10:1. That was an OK number for me since i did make 486 Ft Lbs of TQ!!!! With the 480 lift cam i had the first time (flattened #1 intake lobe) i ran low 13's in my RS. Not too sure where 400HP is being figured into this motor?
P.S. i was only using GM rods and crank, but forged TRW pistons.
Old Mar 8, 2004 | 10:49 PM
aklim's Avatar
In summary, if you cannot get it independently verified by an independent dyno, assume that figure is inflated.
Old Mar 9, 2004 | 05:55 AM
GTO2Z28's Avatar
Thanks guys for all the feedback. I am going to call my friend tonight, report this, and get the rest of the parts.
Old Mar 11, 2004 | 10:32 PM
GTO2Z28's Avatar
Complete specs:
GM 2.02 1.60 Heads (not Vortech)
480/230 cam
4 bolt main 350 block with nodular caps
Roller Tip Rockers
Hypertech Pistons
Molly Rings
GM 400 Crank
GM Rods
Edelbrock Performer Intake
Balanced with ARP Bolts
It is not forged
$2200 for everything
He would be adding a Demon 625 carb.
