going insane! can't find....
Old Aug 24, 2003 | 11:18 AM
shwine617's Avatar
I am going crazy trying to find the block number on my 90 camaro, the car had an engine swap and I need to find the block number, any thoughts would be great!
thanks!
Old Aug 24, 2003 | 12:13 PM
FishPig's Avatar
check these areas. v-6 vins 82-83 are stamped at the top center of the eng block behine the water pump, 84-88 is stamped on the left side trans mount flange, v-8 front of the engine block right below right cylinder head. try those locations and see if you can find it.
Old Aug 24, 2003 | 01:36 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
For a V-8 look in frontof the passenger head. It will probably be covered in grease and be hard to read. Will be a mixture of letters and numbers. All you eally need is the Engine Suffix. The last 3 letters of that code that is. Get those 3 letters and you can easily tell what the motor is.
Old Aug 24, 2003 | 08:17 PM
shwine617's Avatar
ok i will check those places tommorow and see what i find, thanks guys
truecontr3
Oct 11, 2015 09:30 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
pimpen1024
Aug 19, 2015 08:36 PM
Aug 7, 2015 01:26 PM
AtlasXVIII
Aug 2, 2015 10:29 AM
