gears! 9 bolt
Old Nov 2, 2004 | 09:14 AM
PonyEtrZ28's Avatar
gears! 9 bolt
alright im trying to find 4.10's or 4.11's whatever some one has for the borg warner 9bolt. ! anyone know who has them. im finding places that sell 3.73's but nuttin more.
thanks
shaun
Old Nov 2, 2004 | 12:49 PM
panther's Avatar
Re: gears! 9 bolt
have you tried www.9bolt.com ?
Old Nov 3, 2004 | 03:49 AM
PonyEtrZ28's Avatar
Re: gears! 9 bolt
yeah ive been checking that site for a while.
but i finally got through to it. i sent him an email. hopfully it comes back to me.
any other company make them?
Old Nov 3, 2004 | 03:34 PM
MunsonGTA's Avatar
Re: gears! 9 bolt
i have 3.70's in my 9 bolt gta. I know they are the only aftermarket ratio made. I don't know who makes them though.
Old Nov 4, 2004 | 07:30 AM
PonyEtrZ28's Avatar
Re: gears! 9 bolt
ok, not knowing where you got them from really doesnt help.
screw it im going to put a different rear end in my car then! since its to friggin hard to find gears for this thing!.....
Old Nov 4, 2004 | 09:52 AM
Dyosis's Avatar
Re: gears! 9 bolt
Yukon makes the 3.70 gears for 9 bolts. I found mine on ebay but I think you can buy direct from Yukon. If I get some time I try to dig up a website.
Edit - You should be able to order 3.70's from here: http://www.ringpinion.com/
Edit again - Look at the Yukon Gear Ring and Pinion Catalog and go to page 21.
Old Nov 4, 2004 | 07:36 PM
Kwiksilverz28's Avatar
Re: gears! 9 bolt
You and me both. And the rear disk brakes are no winner either. So, I am either going to go a 98+ rear with the new brakes like my 98, or a 3rd gen rear with drums....
Old Nov 4, 2004 | 08:02 PM
Zepher's Avatar
Re: gears! 9 bolt
If you go with the 98+ rear with your stock GTA wheels, it will set out a bit. Not too bad but I didn't like it too much.
Old Nov 4, 2004 | 08:33 PM
Re: gears! 9 bolt
[QUOTE=Zepher]If you go with the 98+ rear with your stock GTA wheels, it will set out a bit. Not too bad but I didn't like it too much.[QUOTE]
Yuck. Hmmm....Wonder if the front wheels have a better back spacing......ebay?
Old Nov 5, 2004 | 04:28 PM
PonyEtrZ28's Avatar
Re: gears! 9 bolt
alright well yes i seen that set. the 3.70's. but see i do need the 4.11's because of the new set up im going to be running. the 3.70s would be eh, ok i guess. but 4.10's-11's would be so much better for me.
and i wouldnt go to drum brakes at all. and i wouldnt mind the 4th rear end only because im planning on 4th gen rims as well! so it would work for two things!.
maybe2fast
Mar 16, 2015 09:45 AM
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
ddr698
Jan 9, 2015 10:05 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
