gauges
Old Dec 16, 2002 | 05:17 PM
Chris`s85Z28's Avatar
gauges
I want to change all the gauges in my Z28 but I want to keep them in the factory places do auto meter make fuel, volts, and temp gauges that small and do they make speedo`s and RPM`s that are factory size? I want to make a plate out of alumium drill holes in it for the gauges and mount them in the factory spot
I don`t want to start mounting gauges everywhere like some people do
Old Dec 16, 2002 | 09:19 PM
TheGreatJ's Avatar
Autometer makes more gauges than you could ever possibly have a use for. Mounting them in your dash is a different story though. The general gauges (water temp, oil press, etc) come in either 2 5/8" or 2 1/16" diameters. The speedo and tach are 5" or 3 3/8". It may be possibly to use a 3 3/8" speedo and tach and 2 1/6" everything else and make it fit in the stock space, but it would be tight, and would require a bit of bracket fabrication to mount the panel. Try taking measurements of the stock panel dimensions and drawing it out on graph paper to see if you can fit everything in. Good luck with it!
Old Dec 17, 2002 | 05:02 PM
Hey thanxs I never thought to draw it on a piece of paper thanx for the idea
Old Dec 18, 2002 | 12:10 AM
99huggerorangeZ's Avatar
Question
im also interested in doing the same thing with autometers phantom series gauges in my 1991 rs tell me how it goes and maybe post a diagram
Old Dec 18, 2002 | 05:04 PM
Sure I`ll draw it out on a piece of paper and tell you if it`s possible with the Autometer`s I hope so it will look awsome if I can do it
Old Dec 18, 2002 | 07:19 PM
deadtrend1's Avatar
have you seen these??
The price is heafty with the guages, but you can also order it without them for like 1/10 of the price
Old Dec 18, 2002 | 09:11 PM
TheGreatJ's Avatar
Looks like they fit just fine. Seems to me you could even run a couple more if you wanted (a/f ratio and fuel pressure perhaps?)
Old Dec 19, 2002 | 10:42 PM
Z28ZL1's Avatar
Re: gauges
If you really want cool gauges, try installing the direct-fit digital guage panels by Nordskog. They are really cool and I think the ultimate in gauges. At night, they look great when they are lit up. The panel is a direct fit and all the wire connections hook up with the stock wiring. Looks just like the newer vettes. Maybe go to their web site and check it out. But if you want to use traditional auto meter gauages, try the autometer nite lite series. They glow in the dark and look great also.
Formula Steve
Sep 19, 2023 08:31 AM
drt
Sep 27, 2015 04:39 PM
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
themex2002
Sep 2, 2015 03:47 PM
