Gauges..
Old Jul 4, 2004 | 07:46 PM
MetalheadZ28's Avatar
Unhappy Gauges..
Can anyone tell me if my 87 Camaro has a wire that makes my gauges work?? And if so where is it suposed to be? Because only my RPM is working and i sucks!
Old Jul 4, 2004 | 11:00 PM
2nd question:
How do u change breaklights or a 3rd Gen. Camaro??
Old Jul 5, 2004 | 08:34 AM
firebirdjosh's Avatar
Re: Gauges..
Care to rephrase that so it makes sense?
Old Jul 5, 2004 | 10:00 AM
Ok. Is there a wire that make the (Gas, Battery, Speedometer, Millage, Temp.) gauges work? Since they all broked down at the same time, or were there sensors in 87 Camaro's?
Old Jul 5, 2004 | 10:08 AM
Stekman's Avatar
If they all went at the same time, i would suspect the harness plug in at the rear of the cluster. There are 2 plug in connectors, check for loose fittings on both, as i forget which harness feeds which gauge.
Old Jul 6, 2004 | 02:32 AM
DPG Omaha's Avatar
There is also a fuse for the gauge cluster, but since your tach works, I'm not sure if that's the case. Easy thing to check anyways.
Meen95z
Jul 21, 2009 06:06 PM
lt1junkie
Mar 20, 2008 08:13 AM
dist0rtion_69
Aug 8, 2007 03:08 AM
woodywagon
Feb 3, 2007 07:23 AM
dist0rtion_69
Jan 24, 2007 11:25 AM
