fuel pump?
what fuel pump?
any recommendations on a real good fuel pump that can flow to alot of horse and do it reliably on a everyday car?
what pump or pumps are you running?
Both Holley and Granatelli make direct replacement in tank fuel pumps that can support up to 800 horsepower. I have no personal experience with these but I know that they offer them. They list both of them on Summit Racing's online catalog. Worth checking into.
I have a Holley external in-line pump. 230lph @ 45psi.
I chose external so I wouldn't have to drop the tank to change it.
Mine does get quite loud at times. I paid $143 at summit 2 years ago for it.
Jegs sells an MSD in-line for $76.99, not too bad.
I think Walbro is the cheapest. They make it for other companies and the other companies mark it up. I have a Walbro high output tank in my pump and it works well for me. I installed it because the pump was old and when I was taking out the tank, I decided to do that at the same time. I didn't want to take the tank out again nor did I want to cut a hole in the floorpan.
internal chris! after what happened with the ati in-line i'm through with that setup if i can get away with it.
i want an intank pump that is reliable and can handle the load. if that's possible?
