Fuel Injectors
Old Feb 25, 2003 | 08:14 PM
ricksmol's Avatar
Fuel Injectors
I have a 1991 305 TPI . I am having problems with the fuel injectors. I have a new set of injectors to put in but I see a discrepancy. The current injectors are rated at 19 lb/hrs. The new set I have is a Bosch rated at 21 lb/hrs. Would this make a big difference to the good or the bad?
Rick
Old Feb 25, 2003 | 09:41 PM
94z'sson's Avatar
those 21lb/hr injectors will be fine on your stock motor but if you run really rich you can adjust the fuel pressure down a little and that might help get the right air-fuel ratio but it will be fine if you jsut put them in there
AdsoYo
May 2, 2018 03:21 AM
daves91z28
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
