Fuel Injectors !
Old Aug 14, 2003 | 02:06 PM
shwine617's Avatar
Fuel Injectors !
hi,
I made a post before about this, like i said before I can't find out what size injectors they are, but this time I have the number off one of the injectors, the number is 9199 and the injector is a greenish color.
thanks
Old Aug 14, 2003 | 02:57 PM
shwine617's Avatar
i found more numbers on the injector , they are 17086542
so that make it 9199 17086542
thanks
Old Aug 14, 2003 | 11:35 PM
aklim's Avatar
According to http://www.pic-fleet.com/theme/frame...Bpart%2Bnumber
They are for the 5.0L. That begs the question. What is the 8th digit of your vin?
Old Aug 14, 2003 | 11:37 PM
Geezer powered's Avatar
sorry didn't see this post Aklim I think the car has a 350 swap.
Old Aug 15, 2003 | 11:04 AM
shwine617's Avatar
thanks AKLIM !!
yes, mine are 19lb injectors, which will explain the fuel starving to my 350, I am probably going to get some 24lb instead of the stock 22.
thanks again everyone!!
Old Aug 15, 2003 | 09:20 PM
aklim's Avatar
Now you are going the other way. You will run rich. You might have to go with someone to custom burn your EPROM if you do. That is unless you are MAF and it might adjust itself.
Old Aug 16, 2003 | 10:46 AM
shwine617's Avatar
yea i know i am gonna run rich, but just for a little while until i get money to get my eprom burned, for now i am getting the adjustable fuel regulator and i am goin to turn the pressure down a bit.
Old Aug 16, 2003 | 11:05 AM
aklim's Avatar
Not sure you can turn it below stock pressure tho. Who is doing your EPROM and what do they think?
aklim's Avatar
Old Aug 16, 2003 | 11:13 AM
shwine617's Avatar
I am not sure who is doing it for me yet, i have to find somewhere in NJ
AdsoYo
May 2, 2018 03:21 AM
daves91z28
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
