fuel injectors
fuel injectors
Anyone know of a good way to clean a set of fuel injectors while they're out of the car. Is there anything you can soak them in? I don't think they're that bad, just thought I'd try to give them a good cleaning while I had them out of the engine.
injectors
i dont know any way of to clean them while they are out of the car, however , im asuming you have a 3rd gen., and 305 tpi injectors are only16lb, 350 are 19lbs, you might want to upgrade to lt1 injectors which are 24lb stock.
Well your info is wrong. At least my information is correct.
305 TPI=19# FI
350 " =22# FI
350 LT1=24# FI
Stock FI sizes....
If you need your injectors cleaned try this Web site www.cruzinperformance.com. Quick service and turn around.
305 TPI=19# FI
350 " =22# FI
350 LT1=24# FI
Stock FI sizes....
Jul 4, 2005 05:00 PM
