Ford injectors in a Camaro?
Old Aug 14, 2005 | 07:33 AM
Frank89IROC's Avatar
Exclamation Ford injectors in a Camaro?
Has anyone ever used these injectors: http://www.hawksthirdgenparts.com/in...?v=1&pid=24268
Any good?
Old Aug 14, 2005 | 08:37 AM
blown3rdgen's Avatar
Re: Ford injectors in a Camaro?
Using Ford Motorsports inj are common, direct swap. Why bother with 19lbs inj? If modded, look for some 24lbs FMS inj.
Matt
Old Aug 14, 2005 | 08:39 AM
91-Z28-L98's Avatar
They will work from what I hear but you may have to have it tuned because ford uses lower fuel pressure than chevy. Just make sure on this before you go with ford injectors. As for how they perform compared to stock, I have no clue.
Old Aug 14, 2005 | 04:36 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Ford injectors and GM injectors are both made by Bosch....
Old Aug 14, 2005 | 10:37 PM
rollingstock's Avatar
as well as over half the other car comps out
Old Aug 18, 2005 | 07:45 PM
stealthblack's Avatar
ford just rates their injectors at a lower fuel pressure.ive got 24 SVOs working very hard right now no complaints, but i will be getting MSD or GM or FAST ones when i step up.
ChrisFrez
Dec 15, 2014 03:09 PM
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
ChrisFrez
Nov 30, 2014 08:41 AM
ChrisFrez
Nov 23, 2014 10:33 AM
