factory plugs or different brand?
Old Feb 13, 2005 | 09:41 PM
BigDaddyWiz's Avatar
i'm ready to replace the plugs in my 84 L69 305. should i stick with factory spec plugs or should i go with another brand? thanks.
Old Feb 13, 2005 | 09:51 PM
Zepher's Avatar
Re: factory plugs or different brand?
I use Autolite but I am going to try the NGK UR4 plugs. going to put them in this weekend when I do my headers.
Advance Auto sells them for $1.69 each.
Old Feb 13, 2005 | 10:08 PM
90rocz's Avatar
The Old saying ,"You get what you pay for", rings especially true for ignition parts. The AC's are stock plugs, good for "stock" cars, once modded you should look for a better plug.
I like Autolites too, but I run Accel's in my IROC and the work great. I've also run Bosch "Super's" and "Platnum's" with good results.
Old Feb 14, 2005 | 06:24 PM
so since my car is 100% stock aside from flowmaster catback and k&n filter, i should just stick with what the stock setting call for?
Old Feb 14, 2005 | 10:12 PM
90rocz's Avatar
The stock plugs will work fine for a stock vehicle, although a better plug will last longer. I'd change the A/C's every year to maintain peak performance.
Old Feb 16, 2005 | 01:24 AM
kandied91z's Avatar
i had no difference in power output on the dyno between champion and ngk's that were similar. however the ngk plugs lasted significantly longer through testing then champions did but in all honesty they were so much more i can't say it was worth it. it's all preference and what works for you, if you know someone to have luck with something go ahead and try it... why not.
now when it comes to wires that's a different story.
Old Feb 16, 2005 | 08:44 AM
Tru2Chevy's Avatar
Yea, I run Accel wires, but stick with AC Delco plugs in all my cars. Never had a problem with them.
- Justin
chevy95z28
Jun 22, 2015 09:28 PM
alliance12364
Mar 6, 2015 04:39 PM
97TA-WS6-Con
Jan 10, 2015 05:31 PM
Collector Car
Jan 5, 2015 10:58 AM
Catmaigne
Dec 25, 2014 12:16 PM
