exhaust setup
Old Jun 19, 2006 | 11:19 PM
michaelxx16's Avatar
exhaust setup
lookin for most bang for buck on my 91 supercharged z28, as it sits now its got stock exhaust manifolds, anyone have a suggestion for headers/exhaust?
Old Jun 20, 2006 | 04:35 PM
LesPaulGoth's Avatar
Re: exhaust setup
Go true duals:
Get Hooker Competition Long Tubes: $149.88 @ summit
Two mufflers that suit your needs
Tips that suit your liking
Take it to a shop that will fab it up for you, say about $150-300 depending on where you go. Buddy of mine got his H-pipe fitted to his chevelle for $160 from a place near me. All in all you are talking $500 for a full system, but will flow awesome, and compliment that SC nicely
Old Jun 20, 2006 | 07:16 PM
streetheatz28's Avatar
Re: exhaust setup
1st - DON'T get flowmasters
2nd - true duals can be a pain and cost alot $$ to do on a thirdgen
3rd - If you do true duals get hooker max flows, flow tech warlocks or bullets
4th - if you go with a single muffler get borla, magnaflow or slp.
Listen to sound clips to see what you like best before you buy.
Old Jun 20, 2006 | 08:15 PM
89Vert's Avatar
Re: exhaust setup
1st- why not flowmaster?,
2nd- true duals is a waste on a 3rd gen, considering full 3" almost flows the same as dual 2.5"
Old Jun 20, 2006 | 08:31 PM
88 irocz 350 5-spd's Avatar
Re: exhaust setup
flowmasters might sound good for a while but then start to crap out and sound like sh*t, thats only for the 80 series they sell though. getting a 40 would be the best choice if you really want flowmaster.
also, does magnaflow even make a exhuast kit for a 3rd gen?
Old Jun 20, 2006 | 09:04 PM
89Vert's Avatar
Re: exhaust setup
my 80 series flowmaster sounds fine and I've had for like 4 years
Old Jun 21, 2006 | 12:13 AM
Re: exhaust setup
huh, well eveyone i talked too said to stay away from 80s when i was lookin for an exhuast, but myabe they were wrong. they all said it sounded good but only for a while cuase somthin in the muffle started to go out, but maybe not
Old Jun 21, 2006 | 12:23 AM
90rocz's Avatar
Re: exhaust setup
Something I'm working on right now...is 2, 2.5" down pipes into a 3" head pipe, into a 3" convertor and 3" intermediate pipe and positioning a 3" inlet/2 2.5" outlets muffler just in front of the rear axle. Fabbing 2, 2.5" tails up and over the axle exiting in stock locations with nice chrome tips.(on my '86 GTA)
Old Jun 21, 2006 | 08:45 AM
jayman350's Avatar
Re: exhaust setup
I had an 80 series on my car right up until it rusted through the inlet pipe and started dragging on the ground. They will sound great for like 2 or 3 months, then the muffler will be broken in and the tone will change. Instead of the crisp sound it had before, it will be more like a droning background noise that only really sounds good under WOT.
just my experience with it. you may like how it sounds afterwards but it drove me nuts, if i could do it again i would go with Dynomax in a heartbeat.
Old Jun 21, 2006 | 06:43 PM
slimdawson's Avatar
Re: exhaust setup
True duals are nice but good luck on finding a shop that will take the time and know how necessary to do it right. If you do, you will pay for it.
I have a simple 3" mandrel setup to an 80 series Flow with no problems. I bought the mandrel I pipe from Summit for cheap. I have 1 3/4" SLPs to a cutout to the i pipe then the muffler of course with regular turn downs. Cheap but effective. I didn't gain much hp when I opened the cutout so either the exhaust flows well or is restricted before the cutout.
Old Jun 22, 2006 | 06:44 AM
teke184's Avatar
Re: exhaust setup
how bout a nice 3.5" mufflex setup. will outflow any 3" catback, and will flow comparable to a 2.5" duals setup.
for some rough numbers on flow capabilities here are the cross sectional sizes for various setups. obviously some physics of fluid dynamics plays a role, but it will give you the idea
single 3" pipe = 7.1 sq in
dual 2.5" pipe = 9.8 sq in....a 38% increase over the 3" single
dual 3" pipe = 14.1 sq in....a 44% increase over dual 2.5" pipes
single 3.5" pipe = 9.6 sq in...only 2% less than dual 2.5"
Old Jun 22, 2006 | 07:45 AM
Zepher's Avatar
Re: exhaust setup
here is a shot to give you an idea of how to run the true duals if you go that route,
Old Jun 22, 2006 | 09:42 AM
glennxx1's Avatar
Re: exhaust setup
thats a pretty nice set up you got there
Old Jun 22, 2006 | 03:38 PM
Aklaim's Avatar
Re: exhaust setup
Running a 3.5" pipe is just too much pipe for an L98. If these motors made the power higher in the rpm band, ok I can see that, but unfortunetly they dont. A single 3" pipe is more than enough to handle anything below 350-400 hp, especially when you're making your power below 4500 rpms and the velocity of the exhaust isnt an inhibiting factor. In this case, bigger is not always better.
Old Jun 22, 2006 | 08:43 PM
Black305RS's Avatar
Re: exhaust setup
i have stock manifolds to a normal cat(as far as i can see) and 3 inch from there to a random muffler that came with the car with 2 3 inch outlets and 3 inch chrome tips.
