Exhaust Help
Old Feb 11, 2004 | 06:50 PM
1984camaroz28's Avatar
Exhaust Help
whould a 3in cat back be enought to let my Big block breath easly... the place in my town wants 700$ to do true dual from headers back... i was thinking buy the cat back... a cut out on each side... cat back choices are
Hooker
Flowmaster
Edlebrock
Borla= to much money
Old Feb 11, 2004 | 08:34 PM
formularpm's Avatar
What kind of big block? A mid 90's 454 barely making 230hp is going to have different breathing characteristics than a built 427. Does this engine have any sort of power adder? Does it have ported or aftermarket heads and a long duration cam? If so, I would recommend dual 2.5in. If you want to run a single pipe, consider a 3.5in or 4in the absolute minimum.
Old Feb 11, 2004 | 08:44 PM
i cant find any where that sells 4in exhaust.....The motor is pretty wild its pushen around 650hp if not more
Old Feb 11, 2004 | 09:24 PM
aklim's Avatar
How about here.
Old Feb 12, 2004 | 01:30 AM
for the 630$ 4in i might as well go to the guy in my town and pay 700 for the true duals
Old Feb 12, 2004 | 01:40 AM
Blownyellow's Avatar
Yeah, you can also pay for the ground clearence issues that accure with dual systems.
Any exhaust shop should be able to make a dual exhaust for our cars for cheaper than 700 bucks, that is unless they are routing it with no compromise to ground clearence.
Old Feb 12, 2004 | 01:47 AM
i still need a custom y pipe made
Old Feb 12, 2004 | 08:30 AM
formularpm's Avatar
You dont need a ypipe for dual exhaust. To properly set it up, however, you do need an h pipe.
Old Feb 12, 2004 | 09:55 AM
aklim's Avatar
If you make all the bends required for the no compromise option, I wonder how they will be able to do it with mandrel bending for that price. If it is not mandrel bent, it will have all kinds of crimps in the pipe.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
May 21, 2015 01:04 PM
Pyrocam 95'
Exhaust System
May 20, 2015 12:51 PM
May 15, 2015 10:43 AM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
