engine vac pressure question
Old Dec 15, 2011 | 09:26 PM
Cbystrack's Avatar
alright the issue i am having now is i have so much vacume pressure that my pcv valve just dose not work..... if with have no throtle responce but if i pull it out of the valve cover it runs great and you can hear the engine sound free of stress again.
i put a filter on inplace of pcv valve but now every time i turn the heat on i get fumes inside the car from the blow by coming out of the filter.....its anoying and i am getting head aches from it.... is there another pcv valve i can try? other than whats called for my car? 87 iroc z built 355 carb'd? any input would be good thank you!
Old Dec 18, 2011 | 12:33 PM
Re: engine vac pressure question
What is your intake manifold vacuum reading at idle?
Are you sure you inserted the PCV valve in the correct direction?
Old Dec 24, 2011 | 03:53 PM
Cbystrack's Avatar
i got it fixed thanks for reading and helping!!!
oldschool
Feb 9, 2016 09:21 PM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
guionM
10
Sep 8, 2002 11:08 PM
guionM
9
Aug 29, 2002 01:48 PM
