Engine setups/dyno results/proven combos inside
Old Jan 4, 2005 | 08:12 AM
Viking's Avatar
Hi…
I'm planning on doing a excel sheet where you can sort/search by heads, cam, power and so on…
ONLY TPI ENGINES not carbs…….
This way it would be easy to look up diffent combos when you have ex. AFR190 heads or if you want 500 hp in your car….
If you have a combo that is dynoed and you are willing to share, post the info here or email me.
Info needed
Cui:
TPI/TBI:
Compression:
Heads:
Cam: (name and spec @0.050)
Intake:
Injectors:
Rocker ratio:
TB:
Stall speed:
Power@rpm: rwhp
Torque@rpm: rwtq
Short comment
/N.
Old Jan 4, 2005 | 09:00 AM
speedingpenguin's Avatar
Re: Engine setups/dyno results/proven combos inside
AWSOME
This would be nice if you can get a lot of results for this. Good luck :-)
Old Jan 4, 2005 | 11:39 AM
Marc 85Z28's Avatar
Isn't that what all the dyno software programs are for?
Besides, 2 identical combos on 2 identical motors don't always achieve the same results...
Old Jan 4, 2005 | 05:06 PM
Rice Killer87's Avatar
Originally Posted by Viking
Hi…
ONLY TPI ENGINES not TBI/carbs…….
/N.
that doesnt even go in the same sentence...
lol im sorry,i had to...no offense to anyone
Old Jan 4, 2005 | 11:36 PM
Viking's Avatar
Changed it to include TBI.
Not all persons have dyno program, many people are asking on
- what cam to use with stock enginge and headers
- how much power they will get with heads and cam for example.
Old Jan 5, 2005 | 04:54 PM
speed9's Avatar
Cool Re: Engine setups/dyno results/proven combos inside
Cui: 383
TPI/TBI: TPI
Compression: 9.5:1
Heads: AFR 210 race ready
Cam: (name and spec @0.050) in.225 ex.234 lc=112
Intake: Accel Superram w/Vortech T-trim 9lb. of boost
Injectors: 36lb.
Rocker ratio: 1.5/1.6 combo
TB: Accel 1000cfm
Stall speed: 3600 continental
Power@rpm: 730hp @6200
Torque@rpm: 690-700lb. ft. @3800-6200rpm
Short comment: the power figures are measured at the crank on a SuperFlow with 100 octane and no intercooler!! if i have time i will post the dyno sheet. this is in a 91z28 also.
dan
Old Jan 26, 2006 | 08:50 PM
elementaltoad's Avatar
Im thinking about a SuperRam on my 350 TPI, Not sure how it with do stock, with the stock manifold. But if i get some numbers, ill be sure to post.
oldschool
Feb 9, 2016 09:21 PM
92ragtop
Dec 27, 2014 01:56 PM
squarehead
Nov 21, 2014 08:02 PM
Nostang 96z
Sep 15, 2002 10:15 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
