Which engine mod next?
Re: Which engine mod next?
89 L98 F-bodies have the 9-bolt rear end, remember? If you have a single catalytic converter you have a 2.77 ratio rear end. The cost of a new posi unit and gears would be well into the $600 range, so try to find yourself another 9-bolt with 3.27 or 3.45 gears. Easier would be to find a 10 bolt from a 90+ thirdgen or fourthgen with disc brakes and swap that in. Dont forget with a gear swap you will need to change the speedo gears in the tranmission so your speedo reads right, and possibly the governor in the transmission as well so it shifts right.
Sounds to me that for $200 you should go with the AFPR, and port the plenum and runners while you have them off to install it.
Originally Posted by '86 350
The "stall" and "converter" are the same things. It's actually a stall converter or a torque converter.
But what in the hell is all this AFPR talk about?
Just pull a posi unit out of a matching rear end and install it yourself. Make sure you put some good gear oil in there, and you can RTV the diff cover back on.
Go back in there a little down the line and do your bearings and etc if you want peace of mind, but for now, that would seem best. You could get out with just the posi unit to add to your rear for under 50 bucks I bet, another 15 bucks on some gear oil and voila.
Then port and gasket match the plenum and runners along with that Adjustable Fuel Pressure Regulator. You could do all this for under 200 bucks if you weren't lazy and hit three or four junkyards for that perfect posi.
I got a posi unit that looked brand new for 35 bucks last year, and someone had already ripped out the spider gears to make it easy for me to pull. A guy I know through a friend offered 100 bucks for it so I let it go.
theres a few 9 bolts that pop up every once in a while, but why would you really want one? yea they are tough rearends, but the gearing/parts for them are hard as hell to find....it would just make things more difficult and more expensive..i'd take a built 10 bolt like mine anyday..
I still say get new gears....its gonna cost you more than 200 bucks, but there isn't much you can get these days for cars for under 200 bucks...
correct me if i'm wrong, but I think he's referring to an Adjustable Fuel Pressure Regulator..
Originally Posted by robvas
All the 87-89 350 cars have 9 bolts, right?
Get under your car and count em up.
Somewhere I heard that a LT1 cam will swap right in and cause a slight increase in power? Yay or Nay? Ebay had one with lifters for $23 + $10ish shipping the other day.
alex5366
Mar 8, 2015 11:32 AM
johnsocal
Jun 22, 2002 12:18 PM
I'll be damned if you find a 9-bolt seeing as how rare they are
