Emission Tubes
Old Jun 16, 2002 | 08:11 PM
92_RS_305's Avatar
Question Emission Tubes
What all has to come off when you take the emission tubes off and the smog pump or sensor whatever it is......what else do I need to take off?
'92 RS w/ 305 TBI, Flowmaster 80 series, K&N Filter.....more mods to come.....gotta save up the cash first though
Old Jun 17, 2002 | 01:16 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Post
You dont "need" to take any of it off. Its there for a reason.
Save yourself some hassle and just remove the hoses going to the air tubes, and cap off the black valves where the hoses were. If you really want to go to the trouble of removing the air tubes too, good luck. They're usually rusted shut and are really difficult to remove. You can remove the smog pump too if you really want to, and just route the belt thru that area with no pulley. I dont know how SC smog laws are, but if you have a visual smog test, you wont pass it if you do this. And also keep in mind that removing working emissions equipment is a federal offense punishable by a fine and/or jail time if you get caught.
1991 Camaro Z28
350 L98 w/ T56 (originally 305 LB9 w/ T5)
318 RWHP, 419 RWTQ
12.803 @ 108.50 MPH (1.932 60')
Member: SoCal F-Bodies
ThirdGen 4-Life!
Old Jun 17, 2002 | 11:56 AM
1989gta's Avatar
Post
i removed all my emissions except the air pump. I'm using that to pull crank pressure out. Instead of getting the inside of my intake all nasty
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
drt
Sep 27, 2015 04:39 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
