EGR Help
Old Jul 7, 2005 | 05:10 PM
rdrokit's Avatar
EGR Help
I have an EGR failure code 32 popping up.It doesn't make a difference in the way the car runs.How can I keep the EGR valve in the car (connected /disconnected),and keep the code from popping up?
Is there a resistor or something made to stop the computer from reading the EGR valve.It just iritates me
Roger
Old Jul 7, 2005 | 08:06 PM
rollingstock's Avatar
Re: EGR Help
i think if the egr valve is bad it will make ur car when lean(might be wrong).. the valve is only like $51.00
Old Jul 8, 2005 | 03:10 PM
92BLKL98's Avatar
Re: EGR Help
I had that once a while ago. Found I had a bad EGR control module (on the back left of the manifold. Engine ran OK just gave a code. Be sure which is bad before you spend your bucks.
Old Jul 9, 2005 | 12:56 PM
rdrokit's Avatar
Re: EGR Help
Thanks for the help so far.I disconnected the wire going to the EGR temp sensor and now I don't get a code.The TPI swappers guide is telling me with no code 32 with the wire disconnected ,I have a short in the wire or a faulty ECM.The car is idling and running fine. My question is ,If i just leave the wire disconnected what can happen? Can I hurt anything?Would there be short or long term side effects to doing this?
Roger
Old Jul 9, 2005 | 08:39 PM
92BLKL98's Avatar
Re: EGR Help
Well last week I tried an annual emissions test with the EGR system programmed out of the ECM my car passed but the NOx was at 762 ppm the limit is 796 ppm. Last years test resulted in a 199 ppm. I decided to do some datalogging. The EGT was about 75* to 100* high. CTS was as much as 115* high and, the knock sensor was very active. I usually see 2 to 3 knock counts on the drive home this time I saw about 30 counts. I believe this would be much higher if ambient temps were higher so be careful obviously my cylinder pressures were pretty high. I tried it to see if I could install my LT1 intake but I think I'm going to wait till I get new heads and install a cam to compensate for lack of an EGR. I did reprogram the EGR back into the ECM to be safe. If I were you I would fix this problem or reprogram the ECM if you leave the EGR out This was a little long winded but I think you can get a little info from my testing.
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
