Edelbrock
Old Apr 21, 2003 | 11:19 AM
85_LG4
Guest
Posts: n/a
Question Edelbrock
Will Edelbrock PART #7501 fit my car?
Old Apr 22, 2003 | 06:57 AM
85_LG4
Guest
Posts: n/a
Umm... nobody knows? I REALY need to know, as I want to buy it off of somebody for REAL cheap... but need to know if it will fit my car.
Old Apr 22, 2003 | 07:28 AM
irocz8957's Avatar
your quite below you question says you have an 85 z but planning to drop and lt1 in it which motor do you want it for the lt1 or the one in there now?
Old Apr 22, 2003 | 01:53 PM
85_LG4
Guest
Posts: n/a
The manifold will be for the stock LG4 305.
Old Apr 22, 2003 | 02:51 PM
Black6SpdTA's Avatar
"Designed for 1955-1986 262-400 c.i.d. Chevrolet V8s..."
-Edelbrock Catalog
yea itll fit. why are you gettin a new intake manifold for the LG4 if youre puttin an LT1 in soon, wont that be a waste?
Old Apr 22, 2003 | 07:14 PM
RadarRunner's Avatar
You might want to check with an autoparts store just to be sure, but even they make mistakes.
Just a few days ago I got the Edelbrock Performer 2101 for my LG5 w/carb, but found out from mechanic that the heads on my car are different, possibly for fuel injection, but 2 or 4 of the bolts go in at a different angle.
Had to take the 2101 back & get a 2104.
Sometimes it is hard to figure out for sure until you get into it.
Old Apr 23, 2003 | 06:26 AM
Zepher's Avatar
Had to take the 2102 back & get a 2104.
In 87 when they went to Roller blocks, they changed the bolt angles on the 4 center bolts in the intake and heads (2 bolts on either head). With the correct bit in a drill, you can modify the intake to fit either style head.
If that intake is square bore, and you are running the stock spreadbore Quadrajet, you'll need to buy an adaptor plate.
Old Apr 23, 2003 | 10:18 AM
85_LG4
Guest
Posts: n/a
Well... i might not be gettin that LT1 any more... lol.
But thanx for the help!
Old Apr 23, 2003 | 06:02 PM
Rather than modify the intake, I got the 2104 & besides have the bolt holes at the correct angle, there was also more room for the bracket/bolt at the right front, & additionally there was the correct spot for a heater connection at the rear.
I went ahead & changed the carb to a Holly 4160, so no adapter was required.
Old Apr 23, 2003 | 08:02 PM
85_LG4
Guest
Posts: n/a
Ah, well... I have the Edelbrock Performer 600cfm carb... so I should be ok... right?
Old Apr 23, 2003 | 11:51 PM
Sitting Bull's Avatar
You're laughing
Old Apr 24, 2003 | 08:11 AM
85_LG4
Guest
Posts: n/a
What is that supposed to mean? "i am laughing"?
G-BODYT56
Jan 14, 2022 11:14 PM
kylekratzenberg
Classic Engine Tech
Aug 25, 2015 10:28 PM
surreybrad
Aug 10, 2015 09:34 AM
dfarr67
Apr 10, 2015 07:44 PM
squinn
Aug 4, 2002 01:06 PM
