Earl's Hyperfirm Brake Line Kit
Old Apr 22, 2003 | 01:30 AM
aklim's Avatar
Thumbs up Earl's Hyperfirm Brake Line Kit
Got mine installed today. They are braided steel hoses and the install works well. One hose for each wheel and another one for the rear distribution block piece. Only problem was that the fronts did not fit but if you hog out the front caliper where the oblong block is mounted to the caliper by a banjo bolt, it works fine.
The pedal is a lot firmer and it is probably cheaper than getting the hoses from GM
Old Apr 22, 2003 | 06:01 AM
94z'sson's Avatar
where did you get them from?
Old Apr 22, 2003 | 07:40 AM
irocz8957's Avatar
how much did they cost you?
Old Apr 22, 2003 | 10:18 AM
aklim's Avatar
Mine were got from Summit Racing. It is $95.95 plus some $7 or so for handling. 4 Wheel disc part number is 28A190. Thyey have front wheel disc for $70.
Old Apr 22, 2003 | 12:19 PM
TRAXION's Avatar
http://www.thirdgen.org/techbb2/show...hreadid=171532
This should clear everything up.
Tim
Jan 23, 2015 01:13 PM
Jazsun
Dec 29, 2014 12:14 PM
CARiD
Dec 26, 2014 04:20 AM
Dec 4, 2014 11:56 AM
