Dual Snorkel...
Old Jul 2, 2006 | 12:03 PM
OneFreakZ's Avatar
Unhappy Dual Snorkel...
hey guys i just install my dual snorkel air cleaner on my 89 camaro rs tbi my question is on the stock air cleaner inside of it where the air filter is i notice that there are two type of sensor i know one is for the vacum but the other one it has a electric plug that connects to the air cleaner????the dual snorkel doesnt have that electric sensor so that i cant connect the plug then i noticed that my check engine light comes on i know its becuz of that sensor thats not connected to the air cleaner???any help please..thanks
Old Jul 2, 2006 | 12:19 PM
tom2's Avatar
Re: Dual Snorkel...
I'd guess it's the MAP/Baro sensor that clips in the old aircleaner on the side.
Old Jul 2, 2006 | 06:07 PM
OneFreakZ's Avatar
Unhappy Re: Dual Snorkel...
no this sensor is under the stock air assembly from my 89 camaro tbi..but on the dual snorkel air cleaner that i got it doesnt have that connector so i could connect that sensor to it????.....what do i do just leave it like that becuz it turns on my Check Engine light on....thanks
Old Jul 2, 2006 | 10:30 PM
Black305RS's Avatar
Re: Dual Snorkel...
that is the mat sensor it tells the computer what the temp of the incoming air is. if you want you can drill a hole to install it or plugf it in and leve it on teh engine. at least that way you will be getting some kind of reading even if it isnt the correct one.
with it unplugged the computer is reading -40 degree F and thus throws a code
Old Jul 3, 2006 | 01:35 AM
OneFreakZ's Avatar
Question Re: Dual Snorkel...
oh ok yeah i will drill a hole but now how do i take the mat sensor out from the stock air cleaner???....i dont wanna break it...thanks
Old Jul 3, 2006 | 11:13 PM
Black305RS's Avatar
Re: Dual Snorkel...
i believe there is a snap ring of some sort holding it in. just examine it carfully and you should see how its held in. it should be held in from inside the air cleaner.
Old Jul 4, 2006 | 12:17 AM
OneFreakZ's Avatar
Thumbs up Re: Dual Snorkel...
yeah i manage to take it off so i drilled a hole big enough to fit that sensor on the dual snorkel air cleaner so it worked fine ...thanks again for your help..
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
