Does porting and polishing help?
Old Jul 23, 2002 | 01:28 PM
  #16
Speed Deamon's Avatar
Post
Shouldn't you know what it is or isn't by now?
Old Jul 24, 2002 | 09:25 PM
  #17
Sitting Bull's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by aklim:
I'll bite. Why? Does detonation come into play or are you reducing it to say 9.5:1 because I believe you can bring it up to 11:1 with Amuminum heads.
That and the weight savings and the ease of the car nose going up during launch would swing it in favor of the Al heads, IMO
</font>
No, it is because the iron heads will retain the heat from the combustion process longer than aluminum heads. This actually allows the compression ratio you choose to be acurately attained. Aluminum dispenses the heat quicker and thus allows a higher compression ratio, but that also becomes a requirement for them to attain the same power as iron at a lower compression ratio.
If they are both set for 11:1, the iron heads will produce more power.
G-BODYT56
Jan 14, 2022 11:14 PM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
